wheel bearing
    wheel bearing
    are automatic and 5speed wheel bearings the same? and are they side specific...aka drivers side is different from passenger side. thanks. basicly im thinking of picking this up and want to know if it will work on my 5-speed
    http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
    www.hondaautomotiveparts.com should be able to awsner this
    *edit* looks like there are three different parts avaible but only one baring in the pic. hmm... anyone else want to tackle this one?
      eric, dont get used ones. this is one part you dont want to cheap out on. plus they arent that expensive brand new.
      and my friend works at les schwab and he said that if you buy a bearing and a hub from them,(and prob any tire place) they will press it for you. thats wha ti am going to do with my rotor over hub.
        well i dont know how long ill have the car...and if i keep the car im gonna do a brake upgrade anyway, so im really not worried about it
          is it possible to take the whole hub/rotor assembly off without a press so that i can bring just the parts to a shop to have the bearings pressed in? it could save me a lot of money if i can...
            alright sorry for all the *** newb questions. but if i were to buy that used hub/bearing assembly in the first post, can it be installed without a press?
              i think you have to have everything pressed back on at a machine shop or something man....but im not 100% sure, maybe try another lifeline.
                um that hub and bearing is a bolt on a fair, the hub and the bearing is already pressed together eric.
                but when you buy a brand new hub it doesnt come with the bearing and there for you need the bearing pressed in.
                also if you have a junkyard close to you, arrozburner managed to get 2 Cl 2.3 whole front knuckles and just swapped the knuckles for 100 dollars.
                  yah, the junk yards around here suck for some reason, or i was gonna do that. and i still might do it over the summer
                    cool keep us posted then!
                      Eric, I just did new front bearings on my Auto. They look identical to the one you have pictured. Yes indeed they are pressed on. Most repair shops can do this. They were $65 a piece at AutoZone. Feel free to swing any other questions my way, I suggest PM.
