Ok I have a 1990 ex. And when you start the car doesn't matter cold or hot. And it backfires out the intake. I Have used a multi meter to check the coil icm and wiring and that all checks out. I have checked fuel pressure and it's 39 psi. and compression is 155 160 180 180 left to right. I can't figure this out. My car just back fires out the intake and has no power what so ever at all. At a loss of what I should look at next. It still starts and runs and drives just barelly.
Back fires out intake and runs rough
Check the timing.
02 Crv
http://www.cb7tuner.com/vbb/showpost...91&postcount=1
I don't know if you can rent a timing gun or not, best bets to call and ask. Sounds like you're a few teeth off, no power and back firing through the intake leads me toward timing.
02 Crv
Timing aka your belt jumped a tooth or your intake valves are out of adjustment. you don't need a timing light to check the physical timing of the crankshaft and camshaft.
If you are constantly running lean then a code 1 will be thrown as your ECU can no longer make any adjustments based on the lean voltage/signals the O2 sensor is continuously sending it. The ECU would be programmed to read that it is the O2 that is at fault.
It will take time for the ECU to throw a code 1 if it is based on an engine constantly running lean. It's not instant unless your AFRs are really lean right away. Another code that may accompany this could be code 43. Fuel supply system
Pull the spark plugs and let us know what they look like on the business end. When was the last time you had the timing belt changed and the valves adjusted?Last edited by GhostAccord; 03-25-2012, 10:06 PM.
