so i been having coolant leaking problems that i could not solve for a little bit knew my car was losing coolant because i would fill the reservoir and i week later i would be empty, i was driving down the street with my windows down then i notice smoke comeing from under the passager side dash i stop and looked under the dash and saw hot coolant drippng on the carpet behind the center council, any idea off wat that can be
coolant leak under passager dash?
Originally posted by C91BLX7 View PostHeater core.
To prevent the heat core from leaking into the car any more you could bypass the core all together. My aunt did that herself on her cb. Just loop a long enough piece of hose from the heat core inlet and outlet on the back of the motor. It a temporary fix and you will be without heat for awhile till your able to get the heat core replace. Good Luck!Originally posted by deevergoteNobody says "Ebonics" anymore... It's thoroughly racist to assume that only black people talk like idiots. This site is proof that EVERYONE, of every cultural background, is capable of talking (or rather, typing) like a total fucking moron.
first make sure the inlet and outlet lines aren't crushed by pliers causing coolant to bypass by them and drip inside. All I had to do was make the metal ports round again and it solved all my problems.
Originally posted by S.W.A.T View Postare you getting any heat when you turn on the heater because the same thing is happening to me.
Originally posted by Raf99 View Postx2. A difficult fix, if you are not sure what to do you may want to seek a professional here. It can be difficult to get to the heater core box to check the lines or replace them. Also if you do replace them upgrade the lines so it never happens again.
