weird tps problem
    weird tps problem
    i got this problem ever since i swapped my f into my civic. i noticed that my cel is on and its showing me that its the tps sensor, but before i swapped the motor the tps was working fine. so i changed the sensor with a known working one, but the code still shows, so i checked the wire harness with a tester and im getting low power to the harness... is there any way that i can up the voltage to the sensor? fyi: i already swapped with another harness that i just put on today..
    Have you tried calibrating the tps?
    CALI LIFE STYLE
    http://www.cb7tuner.com/vbb/showthread.php?t=145883
      yup, but still no luck...its like the tps isnt getting enough power from the harness.
        so measure what it is getting...id look into checking the pins at the ecu.
        I <3 G60.
          will do, most likely will check the pins tomorrow because im getting sucky mpg since this problem...
            well i checked my pins and everything is fine...i added more grounds, but it stays the same. I am really stumped with this
              so...whats the voltage at idle and wot?
              I <3 G60.
                My friends machine broke so I'm gunna buy one tomorrow from harbor freight.
                  try both of the outside wires for the ground... i just did mine and if your looking at the back of the plug the left one worked better on mine and the center for the positive, its easier if you take the TB off and go from there, i ended up just slicing the wire a bit down from the plug(cause i couldnt get a wire jammed into the plug to work) just wrap the wire around the ground/pos ends of the gauge and then wrap the other end around the wire where i sliced it... this worked very well
                  and the tps HAS to be pluged in to get the right voltage
                    problem solved! i bought a multimeter and switched to another tps sensor and the cel went away.
