ok here is the situation:
about a month ago i replaced the intake manifold gasket and changed the plugs.
over the period of a month i have had an exhaust leak at the flex pipe that has gotten worse and worse never affected the engine performance.
the other day i took my car to a shop to get a estimate on fixing the exhaust, as i was leaving my exhaust scraped once again and since then the car has sounded like it has a missfire and has zero power (h22)
only check engine light i get is egr which wont go away. cleaned it and reset ecu. Vtec still kicks as usually just with alot less power. feels weaker than an f22.
i had the exhaust welded up today thinking the o2 may have been associated with the problem due to it being so close to the leak.. still i have No power.
the only to describe it is this... shuddering, hesitation, sounds like missfire.
in the past i had an issue when the car would sit for a little while then when i would start it up again a few hours later i would go to accelerate and it would hesitate like it wasnt getting enough fuel if i opened up the gas it would come out of it and drive perfectly fine for the rest of the drive. <--- could this problem be my issue as it may have gotten worse over time and now its basically in a nutshell acting this way ALL the time
today i checked my plugs (changed again)
cleaned egr (cel still on for it)
checked for vacume leaks
tomarrow my plan is to take off the dizzy cap and inspect
i may be WAY off but could this be syptoms of a failing fuel pump? h22 has been in the car with oem pump for 2 years now.. the chassis has 226,xxx miles on it.
