Wagon wont start. please help!!
    i have a 1993 CB wagon, bought it week ago not running. changed the dizzy, the coil, map sensor, main relay, and ECU, checked all the grounds, all the fuses, still wont start. im getting spark, getting gas. i also changed spark plugs and wires. need to get the car on the road ASAP! im completely stumped. dont know what else to check. any suggestions?
    (p.s i tried to search for threads and i got a data base error so i made a thread)
    wen yous in da import seen yo, u gotta tipe lyke yous from da streetz cuz it showz dat u git mad rezpect yo. toonerz dun tipe lyke dey gotz a edjakashun cuz dat aint coo.
    Fuel pump? Injectors? Fuel modulator(I can't think of what it's called...something like that)?
    '94 JDM H22A: 178whp 146wtq
      fuel pumps good, injectors are good, and i changed the lil box ur talking about to and still nothing.
        Could be your fuel filter?
          thats like the only thing i havent changed yet. ima go do that and ill let you know.
            Try to see if you can get it to start with some starting fluid. Rules out the ignition system.
            The timing on the distributor might be off.
            wat?
              Look at my dude Geroge! Is it turning over? Or is it doing nothing?
              Bought from:AbsurdNY,92smokeaccord,cb7inct,nevi325,xkjnboix,cb 7resurrector,JoshM
              MRT: http://www.cb7tuner.com/vbb/showthread.php?t=203451
                Have you checked for compression, base timing of cam and spark?
                A&P-IA
                  you were right, timing was off..
                  Mark bro, whats up man?
                  got it thankyou!
                    http://youtu.be/2mg33G9iDU4
                    timing was off, you'll see how much it was off when u see how i have the distributor.. motor is fucked :'(
                      Sounds and looks ugly. You'd better check the cam timing relative to the crank.
                        yea the valves are bent from being off timing. thanks for the input everyone. Appreciate it
