AC/heat is not working right!
    I turned on my heat last night (11/25) and it worked. Then I turned the car off. I came back a few minutes later and started the car again. The heat didn't work. I didn't work for the next couple of times I was in the car. It finally worked again this morning. What do you guys think this could be? A switch? A fan motor? Something else?
    FSAE(F Series Accord Enthusiasts) "A dying breed..." #15
    Need parts? Check out my 1990 EX part out!
    http://www.cb7tuner.com/vbb/showthread.php?t=60011
    www.clemsonscc.com
    I in my opinion would say check the radiator fluid this happened to me before. YOu may wanna check the fans fuses or perhaps it can be your heater core the shit thats inside behind the dashboard on the passengers side near the firewall on the inside of the car maybe its just about had it
      The same thing happened to me. I checked all the fuses and everything was ok but didnt work. Then one night it suddelnly came on hot as hell. Ever since than i had no problems.
        mine doesnt work at all dont fell to bad
          Thanks. I will check those things. Thanks for the replies. Sorry it took me so long to post back. I haven't been on as much lately. Thanks again.
          www.clemsonscc.com
            Heater Issues
            When my heat stopped working intermittantly it turned out to be the blower motor. I did some research and found out how to replace it myself. It takes a while because it's really cramped under the dash.
            If I can help, just let me know.
            Tricia
              What's up JBauer! How much did it cost you to replace it? I had a shop give me a price and they said the blower was $200 and the labor was $100. Is that a reasonable price? Also how hard was it to do yourself? How long did it take? What tools were needed? etc. Any info would be a big help! Thanks!
              www.clemsonscc.com
                dont forget to check your fuse under the hood and on the corner driverside kick panel that happened to me before hope this helps.
                  The part cost me about 90.00. It did take a while because it's kind of hard to get to, but it's not that difficult to figure out. Check out WWW.AUTOZONE.COM and go to the repair guides section, it's kind of vague, but it's what I used. The blower motor bolts into a plastic housing, you just remove the entire housing. On my car, which is a 90 LX, the blower motor is on the far passenger's side, directly under the glove box. E-mail me at TriciaLoves99@aol.com and I can send you some pages from the repair manual. Hope this helps...luck!
                    Thanks, I will be sure to check these things out! I will post again if I have any more questions. I might could even do a diy.
                    www.clemsonscc.com
                      Well, there is no need to do a diy. I had the shop fix the heat today. They replaced the blower motor. My parents insisted that I get it fixed. Oh well. They footed the bill so what could I do? I wanted to do it myself but it is probably better this way!
                      www.clemsonscc.com
                        Don't you hate it when that happens. When ever i wanna fix something or touch something they gotta complain. Wait until i put in the h22, man will i hear it.
                        But i was just gettin ready to fix mine but it came back on and since it was 20 degrees all week, i will wait till it goes out again.
