what is it? mine is leaking and i dont know what to buy or what it is
What does the oil filter screw into?
yours is probablly blue though
C-3PO's MRT USDM yo!
wait.. so did i help or no?
Your EX Auto has an oil cooler. This oil cooler uses a large o ring that goes in between the cooler and the block. You would need an oil cooler o ring. Honda PN: 91316-PE7-730 O-RING (62.4X3.1). Not sure if the parts stores will have these, they could. Oh, also, make sure ahead of time you have either a 30mm socket or a large enough adj. wrench to get the oil cooler off. Socket and torque wrench for final torque would be best.Last edited by Granite CB7; 01-26-2012, 06:39 PM.
Originally posted by thepowderblue View Postthe oil filter comes with a new o ring, thats what we are talking about right?
if the parts guys cant find you the o ring for the oil cooler this is what you do. go get 2 oil filters that fit your car take the o ring off one of the filters and it will fit between the cooler and the block and use the other filter when you change your oil. the O ring on the filter is the same size as the one from honda.
IT IS WHAT IT IS
Originally posted by HardInThePaint View PostNaw its a separate gasket. If u remove the oil filter there is a 22mm or 23mm nut that goes around the threaded part. Take that off and there is a o ring gasket that be messing up sometimes. I would go ahead and replace the oil pressure switch while your at it since u will be in the vicinity. That can make your shit leak too.
Originally posted by vh22accord View PostO ring on the filter is the same size as the one from honda.
Originally posted by 1993 CB7 LX View Posti thought it was a 30 mm?
