I ordered an ngk sensor to finally fix my check engine light and it was warm the other day so i was checking out how to replace it before it got here. I have an F22a1 canadian ex (like the us lx) and I never noticed this before but the fan is actually the reason my sensor hasn't been working, the fan's blades had cut through a couple of the wires on the O2 sensor, has anyone else had this problem before because nothing came up when i searched it and i wanted to know if there was anything that can be down so i dont ruin another sensor and have to buy one again...
Oxygen sensor vs fan
Originally posted by ExplodingCake View PostZip-tie the wire away from the fan blades.IG:worldboss_sanjcb7
Only tie with away from the blades. It's not enough force to alter anything , unless you muscle it in.
1996 Honda Civic LX 2009-2012
2012 Kia Optima LX 2012-2013
You should be fine. Just ziptie it back to the o2 body. Remember that the fan pushes air into the engine bay so the blades will bend away from the sensor a little when they are running.
Your other option is get a slim fan.My Member's Ride Thread
i wish my o2 was in the downpipe, any 22a1 owners had this problem before? hopefully the old sensor was replaced with a wrong one before and it stuck out a lot longer then it should and i wont have this prob with the new one...if i'm going to get a slim fan, the fans just slide out right?IG:worldboss_sanjcb7
Why need a slim fan when you can get problem fixed for free? Just asking. It's pretty senseless to opt out for a slim fan when you can fix it by zip ties.Last edited by ExplodingCake; 01-10-2012, 05:06 PM.
the zipties alone still seem to let the wires touch the fan a bit, thinking of zip-tying the fan up a little bit cause there is a little it can move forward as well as the sensor wires back a bit and maybe taking the sensor wiring off that bolt connecter and tucking it, does the sensor just pull out like lefty-lucy? cause i've tried left and right and no movement at allIG:worldboss_sanjcb7
