I made sure the heater valve is working and that the coolant didnt gel.
Basically, whenever it gets really cold (below freezing) my heat does not work as well as it did before. It starts of nice and warm, but after a while it dosent get warm and gets colder. The faster I drive the colder the air gets (Its not as cold as outside, but its not warm either). Yesterday(It was like -20c out) I was driving on the highway for a while and it was soo cold that frost built up on the inside off all of my windows. I had it on heat with the fan at 3 on the defogger and it could barley defog it. (If I put it on higher fan speed it would just blow out cold air). When I got to my destination, I popped the hood to check if all the hoses were hot and the cooling fan came on. I havent driven my car in 3 months time, so I may be off here, but it also seems that the temp guage is a little bit lower than I remember it.
Another thing. Whenever I drive in really cold weather for an extended period of time, whenever I put it in neutral the idle jumps from 1->2k. This only happens when Ive been highway driving in the really cold weather. It has to be some valve on the Intake manifold. Any Ideas?
All my research says that my heating problem is a clogged heater core. Any way to check it or try to unclog it without removing it?
