manual Vs auto H22
    manual Vs auto H22
    what are the differences between an h22 from an auto car, and one from a manual?
    F UR K
    MRT- http://www.cb7tuner.com/vbb/showthre...=1#post2804186
    the trannys and throttle bodys.5 speed has a bigger throttle body.but either way they make 200hp
    my new turbo build
      They've got the same size 62mm throttle body, just the rotor that holds the cable is different since it has to hold the kickdown cable and the throttle cable.
        the vtec powerband isn't as good. you can hit it but you will fallout easier vs a manual. its okay to drive though to get a taste of a h22. when i got my swap done the auto is what i started with.
        91 Ex CB9
        JDM h22 auto swap, now w/H23 5spd conversion, short ram intake w/K&N filter, DC ceramic header, 2.25" custom catback exhaust, AMR Engineering coilovers, 205/50/16's Enkei RS5's, front slotted rotors, Xenon body kit.
        W.I.P.
        p72 ecu on Hondata
        To Come
        Weight Reductions
        R33 or R34 front end
          he means the motor itself that was original in a auto or 5 speed car not how they perform diff as a uto or 5speed.
          my new turbo build
            So if you have a thottle body from a 5spd with an auto tranny, will there be any problems?
            Are h22 and h23 throttle bodies interchangable?
            CALI LIFE STYLE
            http://www.cb7tuner.com/vbb/showthread.php?t=145883
              The engine itself is exactly the same, to my knowledge.
              Yes, H22 and H23 throttle bodies are interchangeable... and yes, you will at least need the throttle rotor from an automatic, not necessarily the whole throttle body.
                i was talking about performance wise, different cams?, or something.. if they are completely the same then that opens a whole bunch more motors to buy..
                F UR K
                  theres on 1 different h22 and thats the type s motor has 220 hp.rall the other h22s are 200hp stick or auto.
                  my new turbo build
                    The Euro R motor makes 220 as well... and the early USDM H22 made 190.
                    But the difference he was asking about was if the auto-equipped H22s made less than the manual-equipped ones. Like the F20B... the auto one makes 180ps, and the manual one makes 200.
