h22a and f22a alternator bracket..
    i'm using the accord alternator which is fine, but i forget if we used the accord or prelude bracket.
    does the accord bracket bolt right up? one of the bolt holes is stripped so i'm just putting a new bracket on.
    just double checking before i hit up the junk yard tomorrow.
      i used the prelude bracket, i beleive they are the same. the difference is in the AC bracket.
        its the p/s and a/c bracket that are different.. the alternator brackets are the same..
          ok cool. makes it a lot easier on me.. the bracket isn't too hard to get off is it? i don't have power steering so there is no pump there, so no pump will get in the way of me.
            thats the only bracket thats in the way of the alternator bracket, so if its non existent, you will have no problems..
              hmmm... ok ...
