I read my Honda Helms manual but its not really clear on what position the dot on the rear balance shaft should be at.
I found an appropriately sized allen wrench to slide in the access hole, and it slides in, BUT, I can slide it in multiple locations. So I have no clue which location "locks" the balance shaft in place.
Does it matter if the balance shaft is locked in the 5-6 O'clock position or the 10-11 O'clock position? because I can fully insert the allen wrench the required 2.914" or 74mm in both spots.
This is for the F22 engine
