Idle problem with P39 ECU!?
    I just got the P39, put it in, let the car run for 10 mins and after about 7-8 mins the tach started jumping from 1k-1500k back and forth non stop, then I drove it and it did the same thing... I didn't have this problem witht he PT3, I tried adjusting the circular vacuum thingie on the top, didn't help. What else should I do?
    You have been defeated by a car with child locks, how embarassing...
    "I noticed my f22 felt "healthier" until it blew up." <Myk>
    Make sure everything that is connected to the ecu is tight. Because when I was trying to take out mine, a wire became loose when I put it in and the rpms went crazy when I was driving.
      Which wire was it? On the ECU or that black one going accross the ECU on top?
        It was on the bottom. The wire closest to the passanger door.
          How did you fix it?
            I just pushed it in and made sure it was securely in there..Then I took it for a test drive and the rpms were fine.
              I took off the battery cables overnight to reset it... Maybe thats the problem?
                None of that worked =( what else should I check?
                  problem fixed... a thank u.. a thank u.. :bows:
                  now onto another problem lol.. he has yet to tell me.. i shall wait on aim...
                  Praise The Lowered...
