Header Down Pipe Questions
    So when I did my swap I figured I'd drill new holes in the Stock exhaust manny which I did successfully. The down pipe and flex pipe from my CB are a little off and the flex pipe is stretched.
    Is there any recommendation or a particular setup that should be used. For example when purchasing these parts should I buy for a prelude or accord.
    IridiumCore
    HCK-The Beginning
    Your drunk she doesn't look that good.
    hey!! you're close to me.
    What swap did you do?
    ----------------My 92 Honda Accord LX---------------------- My 97 Nissan 240sx LE----
    NE GUYS, Buy the last of my accord parts
      H22. I did alright but I got a problem with either the fuel injectors or the fuel filter which I'm replacing today. I took off the fuel filter and the fuel that was in there was black.
      IridiumCore
      HCK-The Beginning
        Why did you drill holes in it?
        Green EX http://www.cb7tuner.com/vbb/showthread.php?t=176536
        93 SE http://www.cb7tuner.com/vbb/showthread.php?t=210486
          Well like a dumby I was relying on my CB's header fitting the JDM H22. (enough laughing) well of course that header didn't bolt up to the H. So I used the H's header with the CB after market down pipe. The holes don't line up so I made new ones.
          IridiumCore
          HCK-The Beginning
            Oh. I was at the junk yard and I say a cb7 with what looked like it had a h22 header So it must of had the matching downpipe
              Oh I was at the junk yard and I say a cb7 with what looked like it had a h22 header So it must of had the matching downpipe
              That was probably an f22a4, not an h22 header, they came stock with a tubular manifold
                it was a welded manifold not a cast one.
                  So what combination should I use.
                  IridiumCore
                  HCK-The Beginning
