ABS Delete for wire tuck!
    ok i want to delete my ABS for my wire tuck and i just need to know is this hard to do and what will i need to do this?
    http://www.cb7tuner.com/vbb/showthread.php?t=176523
    your going to need a non- abs proportioning valve, 2 non-abs front brake lines and a flare tool and your good
    Just do what PR CB7 said.
      Ok thanks! Is it hard to do?
        Yes
        -Will
          Hard if you dont know what your doing and if you wont have a way of transportation while your car is down....my abs doesnt work but i avoided doing it because i needed my car on the road...on my to do list but not for a while
          Originally posted by Uncle Willey
          When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
            you dont know what your doing, have someone experience with this help you or do it for you.
            Originally posted by Juice21
            thnx pimpette, your car inspired me to go lower
            Originally posted by GameChewer
            Shiit i heard that, you heard the queen!
              Who says I don't know what I'm doing I just like to see other ways that people may do it other than me. I clearly just wanted to get opionins on how to do it because there are different ways you can route the new brake lines. So clearly if your not going to help me on what I asked for then do not post here!
                  I consider myself pretty experienced, but it took me around 8-10 hours simply because nearly everything is corroded and space is tight. Watch cutting the small line from the ABS unit to the pump in the front. This line is a high pressure line which will most likely still be charged. Mine was even after 6 years of the ABS computer being removed. Also, expect to have brake fluid everywhere, my hands were so soaked in the stuff that they were pruning.
                  It does clean the engine bay up and make the brakes feel better, but if its working you should probably just keep it. At least until you have the motor out and can get to the lines easily.
                    if you knew how to do it, you wouldnt be on here asking questions on how to do it and what you needed.
                    MR:http://www.cb7tuner.com/vbb/showthread.php?t=150506
                    CHAMPCOUPE IS BACK !!!!
