help with shaking
    help with shaking
    so heres the problem, i'll make bullets so you dont have to read through paragraphs
    - typically shakes above 45mph
    - stops shaking under braking
    - makes rattling noise, clunking
    - shakes steering wheel
    - sounds like its coming from passenger side
    Recent repairs:
    - new rotors, pads
    - new power steering column
    - new cv joints(both sides)
    - new clutch and flywheel
    - new tires and balance 5 month ago
    also today, hit a bump and something fell off my car after hitting the bump, couldnt visibly see anything missing except one bolt, pictured below
    red dot=missing bolt on the smaller bar
    ^^^^ me trying to kill myself after i saw the gas prices.
    MY H22 COUPE ---> http://www.cb7tuner.com/vbb/showthread.php?t=75025
    try replacing the bolt and see if the shaking goes away? That's your radius rod support arm, ties into the front cross member and locates the control arm so it doesn't move around while driving. I could see that causing a vibration if its not properly secured.
      Well it wasn't the missing bolt. Maybe I'm over thinking, could possibly need an alignment?
