Bad Compression
    Bad Compression
    Hey guys, so last Saturday I performed a compression check and this is what I read
    • Cyl #1 125psi
    • Cyl #2 198psi
    • Cyl #3 198psi
    • Cyl #4 198psi
    My Haynes manual tells me that stock is 180 something for stock comp and minimum recommended compression is 135psi
    I think I have a set of bad piston rings in Cyl #1.
    I just rebuilt the top end of the motor about a month ago.
    New head gasket
    Head was milled
    Torqued properly with arp headstuds
    The head only has 14k on it
    I really dont want to take my motor apart, but it looks like I have to.
    Originally posted by Gummiegorilla
    Damn CBs are like a Rubix Cube sometimes !!!!
    Do this old trick take a cap full of oil put it down the low psi cylinder.Retest the compression if it jumps up 20+ psi its the rings.What the oil does is temporarily seals the rings.If it doesnt jump up the psi to much it will be the valves.Hope this helps.
    02 Crv
      What about damage to the cylinder wall?
      I guess milling the head boosted the compression from 180 -198??
      Unless he is running different pistons, which was not mentioned..
        SOHC-FTW, thanks i will try that
        Kronikally420, the milling did raise the comp my motor has 269k on it and im running stock internals
        if my calculations are correct I think i am running 9.4:1 compression ratio, this is also combined with a stage 2 cam regrind which allows my engine to suck in more air.
          Are your valves closing all of the way?Mabe you have the valve lash is set wrong so they cant close all of the way.
          Green EX http://www.cb7tuner.com/vbb/showthread.php?t=176536
          93 SE http://www.cb7tuner.com/vbb/showthread.php?t=210486
            generally rebuilding the top end isnt recommended on a high mileage bottom end.
              Yea my friend redid his 250k F22a head gasket and it blew again a couple months later
                Leak down test.
