well ive been having this little problem with my clutch, when i press it all the way down to start it, i give it crank but it doesnt do nothing until i hit it all the way to the firewall like slam it then it turns on so im guessing the sensor is bad or going bad how do i replace it? or what can i do to fix it? or can i put it direct so i wont have to use the clutch to turn on the car, if so how? thanks in advance guys.
clutch issue
clutch issue
AT WEST COAST MEET
cb7rush: who has the tongs?JDMxDB8: i got a thong on...
to get to see more of my cb click the link below.
http://www.cb7tuner.com/vbb/showthread.php?t=130922Tags: None
Originally posted by iwork4mycb7 View Postwell ive been having this little problem with my clutch, when i press it all the way down to start it, i give it crank but it doesnt do nothing until i hit it all the way to the firewall like slam it then it turns on so im guessing the sensor is bad or going bad how do i replace it? or what can i do to fix it? or can i put it direct so i wont have to use the clutch to turn on the car, if so how? thanks in advance guys.
Yes you can bypass the sensor, google is your friend on this one. Its super easy.Originally posted by wed3kim a douchebag to people and i don't even own a lambo. whats your point? we, douchbags, come in all sorts of shapes and colours.
