p/s removale q's
    p/s removale q's
    when you remove the p/s totaly, do you loop the return hose into the port the pressure side used to be?
    or just cut & splice the 2 togeather?
    i've currently got my belt removed and it's annoying. i assume removing the pump and tank will cure the exsive pressure w/ the pump not spinning.
    nobody knows?
