-in mornings car takes 2-3 secs of cranking to turn over. after turn over, car idling, if i press the gas the RPMs rise like normal but then fall really fast to the point of almost stalling... sometimes it does stall.
-Also car is 5 spd and when changing gears the RPMs hesitate (sometimes rises a few 100rpms depending how much throttle) for a lil while and then fall.
for more details on my problem read the bottom.
Well in the morning when i start up my car it takes a while to turn over... about 2-3 secs to turn over. Once it turns over if i hit the gas pedal a little bit the RPMs will go up and then drop super fast to the point of almost stalling. sometimes it stalls out but it usually picks up speed after dropping. i usually wait about 10 secs before i touch the gas pedal for this to stop and run normal. also my car is 5 spd so after it is at normal operating temperature if i were to put it in 5th gear and put it at wide open throttle and then release the the gas pedal and at the same time press the clutch (clutch neutral status) the RPMs will jump up about 500 RPMs then fall back to idle. even when changing gears in normal driving the RPMs hesitate then fall until i go into the next gear. Im thinking this hesitation problem is from the TPS (throttle position sensor) but dont kno how to check it. usually when cars decelerate little to no fuel goes in right? so im assuming that car still thinks the throttle is open and dumps fuel in anyway for a little while then realizes its not open anymore. kno what i mean? for the cold start problem i think it is a fuel system problem but dont know what to check. help me out guys! car runs good other than these problems but they just irritate me.
ive also noticed after switching out my stock fly for a 12 lb act fly my revs didnt fall any faster than stock. as for rising i cant remember.
