cant get off blower motor fans
    ive come this far and jus cant get the blower motors fans off the blower motor to place them on the new blower motor. the clips are off and the ends but the metal on the tips seem to be wider than the ends on the fan
    F22B Swapped CB7
    They're on there pretty good. I remember having a bit of a time getting them off. I'd say try a bit of WD40 and then try and walk it off, like shimmy it side to side. Progress will be slow, but it'll work.
      use a heat gun and be gentle
        you kinda have to pry them off, they're sorta press fit on there, pull really hard, but make sure you pull or pry on a spot where its braced well so you won't break any of the fins on the fans.
        I used a really skinny flathead to pry it and it worked.
        member's ride thread
        91 Accord SE 176k
          thanx, i used a different method but i got everything working properly.
          F22B Swapped CB7
