Fluctuation in Temp gauge
    When i went to do test for TPS i unpluged the cable by the driver upper shock mount. I didn't realize the car was on when i plug back in.
    The car won't start. I blew a fuse.
    everything is working now except my temp gauge.
    car been sitting over a week. put the key in and it went to H then L then H and Middle
    Did i kill temp sensor? or my gauge is busted?
    it was working fine before i did TPS adjustment
    anyone?
      so when your driving normally after 10 minutes, what does the temp gauge show?
      RoaR MRT
        still on high
        I disconnect single wire on the head for Coolant Temp Sensor i think
        and my gauge is at C when i plug it back in it went back on H
        bad sensor? or gauge issue
        Edited:
        I will do this test and report back
