I just swapped an H22a in my CB and now I am having issues. 2 ECUs are being used to figure out the issues.
P28:
No check engine lights
H22a map with 8k rpm redline and 6k VTEC
Bounces off rev limiter at 6800 and check engine light comes on when it does that (shift light? its supposed to be set at around 7500)
Idles at 1500
No VTEC
P0F:
Check engine lights for EGR, O2, and who knows what else
Bounces off rev limiter at 6500
No VTEC
idles at 800
I can't seem to figure out what my problem is. I set my TPS at .45 volts and it read 4.28 wot so it should be fine. Everything is hooked up and works great. I am currently running the internal coil distributor that it came with and I have a fuse in the coil plug like shown in a DIY. My temp gauge works and I know I have all my wiring correct. I am also running open down pipe as well. I have wiggled and checked all connections to the engine and computer and everything looks great. Its got a fresh oil change with 4.5 quarts of oil. Its so clean on the inside its crazy so I can't imagine having a clog somewhere in the solenoid screen. I am stumped and I can't figure out whats up.
P28:
Idles at 1500
No VTEC
P0F:
No VTEC
idles at 800
