ok, so I did the swap about 3 months ago and did a wire tuck. now one time when i was driving the car lost power and stated trowing blue smog. i found oil in cylinder #2. now the car is at my friends shop and they turned on and it wont smog, compression is good. but when i set the key into the on position it starts pouring gas into the cylinders. one time it filled the cylinders and gas came out of the throttle body. i put a fuel pressure regulator and nothing, put another ECU nothing. I never seen anything like this. please help.
H22 really weird problem
the thing is when i leave the key in the on position the injectors start to pour gas nonstop in the cylinders. one time i let it do it and it filled the whole intake manifold and thats when the gas came out of the throttle body. im going to check the resistor box. is there a way to test it?Turbo F22 Under Construction
