So I just noticed im leaking oil and no it isn't the VC. Its around timeing cover area im probably going to tear it apart this weekend but if any body can give me a idea of what to look that would be nice thanks.
Leaking oil Pics inside
drop the one motor mount on the driver side,u have to remove balancer belts loosen the tensioner. give the t belt some slack. remove the cam gear. then u can then get to the cam seal. then just carefully install the new cam seal in making sure not to pinch it. might be wise to do the other seals and timing belt and water pump at the same time.
