Okay here's the deal. I got a 91 EX auto with 125k about 3 weeks ago. I test drove it many times before I decided to buy it. Lately, when it changes from 3rd to 4th, the RPM hand shoots up to around 4-5,000 and then changes. Is this a serious trans problem? It only does it when the temp outside is under 50, but on warmer days, it changes fine. I've checked the trans fluid and added honda ATF and some Trans Tune on this past Sat. It seemed to help for a little while. I tried searching but I had went through 11 pages and nothing really helped me. I did find out that I need to get a front motor mount though.
Okay, now I need to make sure I'm seeing the right thing on the stick. one side is flat and has ATF at the bottom when I check it (the fluid is like a little drop at the end of the stick), the other side with the X's (that's how I describe it lol) has it, which side should I check. On my Altima, the stick has L and H so I know if it has enough. Maybe I don't have enough ATF??
All help will be greatly appreciated!!
