goo thing forming??
    goo thing forming??
    theres this goo like thing growing in my radiator. ive noticed it floating on the antifreeze and on the bottom of the radiator cap.
    what is it?
    old sludge. i recommend you get a rad. flush kit .
      take out the thermostat, drain coolant, and run a water hose through your system.
      THen get that radiator flush stuff and put it in there and drive for at least 40 miles (because no thermostat). Then flush again with water.
      Then drain and get all the water out that you can, and then fill it with 50/50 antifreeze. Probably a good time to change the thermostat.
      Retro!
      Hater
        Or oil from a blown headgasket.
        Have a headgasket test done, just to be sure.
        My 5.7 LS1 Holden Ute
          what color is it? can you take a pic of it?
          member's ride thread
          91 Accord SE 176k
            Its a very lite grey color. Ive also notice dripping from under the car when i drive it for a while. I see yhe drip comnh from thermostate area but not to sure
              yeah what I would do is reach underneath there with your hand and find out if there are any wet spots.
              I recently had to replace that colant bypass hose, that U shaped hose that goes from the thermostat to the intake manifold on my beater DD car. That was about 10 bucks at Checker Auto.
              But the only way to find out would be to do a visual inspection.
              91 Accord SE 176k
                is there a diagram showing all the coolant hose? because i think i know which one is the leaking hose but im not sure how many coolant hose there is
                  www.hondaautomotiveparts.com has good showings.
                  ...is it an automatic or a manual?
                  Retro!
                  Hater
