car shudders when i take off in first
    used the search function but it wasn't working right or something.
    lately i've noticed when i take off in first, and sometimes when i shift down to 2nd when taking a slow turn, my car shudders/vibrates. it mainly does it when i first get in it and its cold, but still does it at some redlights.
    i've read around on the net that it could be the clutch going bad but also have got varied answers as well.
    anyone have/had a problem like this?
    We are all ricers, it just depends what flavor rice you are.
    Minitrucker by heart, CB7tuner by coincidence.
    My For Sale Thread
    Bowling Pin Shift Knobs
    From what i've found so far it could be one of many things with the clutch. If you haven't done it before you might want to get a friend that knows more about them or possibly take it to a mechanic to have them check it out. I searched around and asked a couple of people and everything keeps saying the clutch plate could be worn, pressure plate springs are possibly weak, the thrust bearing could be faulty, or it could have oil on the clutch plate. I really don't know but like I said that's all i've found.
      How many miles you got on that clutch
      Retro!
      Hater
        its got 215,000. as far as i know its never been changed because my mom has had it since roughly around 140,000 and it became mine around 165,000.
        i know its long overdue for something like this to be going bad that why i'm trying to figure it out before it gets any worse.
        My For Sale Thread
          Could also be bad motor mounts.
          Project wagon! Much excite! 2018!
          That Sedan. Purchased '07-->Swap'd-->Tuck'd-->Wreck'd-->May '16
            yeah i've also considered those as well because i know my front mount has a crack in it, and i haven't checked the others.
            My For Sale Thread
              if it grabs and shakes it can be the clutch disc. but if you say it does it when you downshift to second it makes me think otherwise. like a mount.
              Does it slip in any gear if you put it in gear and floor it?
              Retro!
              Hater
                i haven't tried that yet. i know for one thing the engine has never "raced" on me while i've been driving down the road.
                i'll try it out and let you know.
                My For Sale Thread
                  tried putting it in gear and flooring it in every gear, never slipped.
                  the only problem i'm really having is it shuddering on take off when the engines cold.
                  My For Sale Thread
                    damn this is a problem? I just thought I was shitty at handling a stick shift. Yeah my car vibrates a shit load when I'm backing up slowly or I'm first taking off. Since it only did this while doing the clutch to gas I just thought it was me. Damn keep the thread alive I want to know more.
                      revv higher and let the engine warm up LOL problem solved. It doesnt seem like a bad issue since its not slipping in gear.
                      check the front motor mount.
                      Retro!
                      Hater
                        Flywheel could be warped, it will cause a shudder just like when your front rotors get warped and your brake pedal vibrates at HWY speeds.
                        MRT - http://www.cb7tuner.com/vbb/showthread.php?t=172713
                        1993 Accord Ex
                          IMO if the flywheel was warped you would have HUGE issues with vibrations at all times since the flywheel is bolted to the engines crank. If you been driving on it long it would of destroyed that motor.
                          Retro!
                          Hater
                            I don't know how warped you think I'm talking about......... NOT like this
                            Over time flywheels can get high spots and need to be machined when you replace the clutch. Not always but it depends on how you drive.
                            http://www.youtube.com/watch?v=RY_r0...eature=related
                            1993 Accord Ex
                              ^now that sounds better LOL. Alot of people misinterpret the word warped...
                              Retro!
                              Hater
