Flywheel bolts
    Flywheel bolts
    Quick question? hope some one can answer it...i need to know the bolt size of the flywheel bolts that hold it on to the crank?? i believe they are 12 point socket but dont know what MM they are. does anyone know?
    Ride List
    1990 Accord dx coupe - my baby (dsm turbo set up in progress) http://www.cardomain.com/ride/3202853
    2005 Mazda 6s - daily driver http://www.cardomain.com/ride/3171724(totaled)
    newest 2006 mazdaspeed 6 http://www.cardomain.com/ride/4073987/2006-mazda-mazda6
    90011-ph3-000 Bolt, Flange (12mm)
      thanx for the response i figured it was 12mm just wasn't sure
      Ride List
        the head is 17mm, the bolt diameter is probably a 12mm
          M12 X 1.00, right hand thread. Lengths are diff. between auto vs. manual.
            I know you didn't ask this but do make sure sure you tourque them down to 76lbs. too. Don't do what I did and have them back out on you and you have to drop the tranny again!!
            The CB7 Collector.
            Team Kindred Impulse Member #3
            92 LX Coupe F22A1
            2013 Toyota Corolla S
            92 EX Sedan F22A1
            Do you really need to make a thread asking if having your car like this /---\ will cause uneven tire wear? Try walking like that for a few weeks and see if your shoes wear funny! (hint: they will.)
              wow that would suck
              for any one else doing this i found this link
              http://www.superstreetonline.com/tec...ion/index.html
              its a 97 but pretty much the same i would guess
              Ride List
                you use a 12 point 17mm socket on those bolts.
                make sure you use a quality socket, so that they wont strip the bolts
