2.5 exhaust header question
    I recently bought a 2.5 catback exhaust off ebay. One of the reasons of which i did so is because my exhaust broke off right in front of the cat.
    this is the exhaust i got .
    http://cgi.ebay.com/ebaymotors/90-93...item43a4737a10
    Problem is, i need the headers and the pipe after that so the exhaust will hook up since its a bigger size exhaust then stock. Can someone point me to some cheap headers on ebay that will work?
    actually, these would be ideal correct?
    http://cgi.ebay.com/ebaymotors/90-93...Q5fAccessories
    I ask this because alot of the ones i find around 1.75-2.0 outlet.
    You should be able to bolt it to your cat, brother, but I'd stay away from a $40 header/dp combo. The quality can't be much good at that price.
      my cat broke off. its pretty much open exhaust right now. Well, im willing to give them a shot anyways, i need to get the exhaust on so i can get the car inspected. Keep in mind, I take it to a friend, which will lick and stick it, but he wont do that with a open exhaust. As long as he sees that theres a exhaust coming out the back ill be good. But can you guys point me out a couple of em?
      Ive had some friends that bought ebay headers, and never had any issues though.
        header meaning one , not headers.a stock F22A4 manifold is just as good as a cheap header.a cheap header has poor weld and tend to crack.even with the 2.5 pipes it will flow about the same as a stock A4.look into a name brand if you want the best bang for your buck.
          If the cat broke off, you need a cat or test pipe, along with the header/dp. The flanges on the pic look thick, the welds look decent, if you're just looking to fake it, go for it, it should last you for a while anyway.
            F22A4 exhaust manifold available on e-bay.
            http://cgi.ebay.com/ebaymotors/ws/eB...STRK:MESELX:IT
              I have a test pipe with my exhaust. I'll just buy one of those headers, and give it a shot
