so my cb only strarts sometimes when it dosent start i can hear starter turn over a couple times then nothing and then a couple hours after turn the key and it starts fine does this sound like a starter problem ???
starter????????
sounds like the main relay if i do say so my self. have you ever replaced the starter while you have owned it ? also hows your alternator ? have you ever drove somewhere and when into a store , and came back and car just spin over ? ten mins . or so it will crank this is how mine did when i first got it , it was the main relay . past starter problems , the starter would just spin quickly and sometime ( whirrl sound and not turn motor over ) auto shop will check your alternator for free.Last edited by stretch JDM; 01-08-2011, 06:28 PM.
cause when it dosent start you can hear the starter spinning the i wait a second then it does nothing at all then went out about 6 hours later and and started up fine sooo i dissconnected battery and cleaned off the posotive and negative and connected it back upLast edited by 93blackcb7; 01-08-2011, 08:00 PM.
