ok guys,
i have been searching for weeks on end. this car idles from 800 to 1500 up and down consistantly. its fine when you first start it but once you hit the brakes or gas the idles begins to go up and down. i have checked all hoses. replaced fitv. adjusted fitv. also replaced iac. i bled the coolant 3 times no air its only coolant. also i have no cel. if i unplug the tps it idles ok but then i get a cel. and same with the iac. i am really lost on this and im getting to the point where i am going to tear off the intake manifold and replace everything with all new gaskets.
its a 1993 honda cb7 ex f22a6 5spd mt
anything is greatly appreciated
