I was cruising down the highway last week when all of a sudden I notice the tach just drop like a stone from 3000 to zero, but the weird part was none of the indicator lights on the dash came on to let me know that the engine had in fact died. After seeing that it took a few seconds to realize that I was just coasting I barely even felt the engine go. Earlier in the day when I was backing out of a parking spot the engine stuttered for a few seconds then went away as well. Anyway now the engine just turns over but doesn't catch at all.
+the plugs, wires, distributor cap, and rotor were changed 5 months ago
I checked the following:
Plugs=no spark
Wires=fine
Distri Cap=Fine no oil residue or burn marks
Rotor= Fine
Put key in ignition turn to on position check engine light comes on then goes off 3 seconds later with a click sound, and I hear the fuel pump come on so the main relay is working.
Ignition Coil=Checked resistance with an ohmmeter and compared results with haynes manual was a little low so I swapped out with a used one from a working CB7 and it still won't start and there is no spark.
Where should I check next? Ignitor in the back of the distributor housing?
any ides are greatly appreciated guys!
Plugs=no spark
Wires=fine
Rotor= Fine
