So I failed smog the other day.. its a 92 accord ex 5speed.. everything was fine as far as CO & HC's.. the problem I had was with NOX.. @ 15mph it failed by 200 points and @ 25 mph it failed by almost 500 points.. the smog guy said he thought it might b the cat since it is an old car.. so my dumb ass replaced it and it turns out my reedings worsened.. the car didn't even pass the pretest after I put in the new cat.. has anyone had problems like this b4?
A little background.. I just recently replaced the dist cap, plug wires from honda, ngk spark plugs, air filter, oil and filter, pcv valve..
I haven't checked the timing yet but I will tomorrow.. also I ran seafoam thru the intake mani on Monday so I could clear up any carbon build up.. also ran some of it thru the gas tank.. not sure if that will help @ all with the high nox or not.. any advice is greeatly apreciated thx
---Luis
---Luis
