Idle shakes
    Idle shakes
    The whole car just vibrates. I have oil in my spark plug tubes, which I will be re-gasketing when I get paid on Tuesday. Could this be causing a misfire which is causing the shakes? My motor mounts seem fine, and this only happens really at idle. When driving I can sort of feel the performance of the motor lagging a little.. Idk, any ideas?
    the oil , on the plugs may very well causing it . when you change the tube seals if it does not clear things up , you may need to look into the idle control valve. good luck man and keep us posted.
      Yeah I cleaned my IACV and screwed down the FITV, then set my base idle. Cold starts rev up to about 1400, and slowly let down, warm has a near-perfect idle of about 750-850. I think I may have a vacuum leak somewhere, but my intake pipe is the original part, isn't clamped down to the tb/im, and it cracked where they connect. Once I have this Valve gasket set replaced on tuesday when I get paid I will be able to see if anything else is the cause of this. Another thing is, would the misfire actually be causing the shaking?
        you might have a bad front motormount by the timing belt they colapse over time and cause a lot of vibration i replaced mine last week, also check your troque mount make shure its not broken,
          GREAT!
          I went to start up my car this morning and for the first time ever it started, idled straight up to 2200, then bogged down by about 500RPM a few times then died. I hope this is related to the valve gaskets so it's fixed when I do that, but it's pissing me off that I don't have any money til I get paid tomorrow... FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF-
          Anyway, what do you guys think it is? Related to the oil in the plugs, or something entirely different?
            Originally posted by jjakimetz View Post
            GREAT!
            yea the oil in the plugs will def cause bad idle. i changed the valve cover gasket completely three times the last time i siliconed it too . but no its leaked again. then the sparkplug wires melted inside the tubes im guessing cause the oil.
