front light
    front light
    The left front corner parking light/blinker quit working. It is reading about 7 volts. All other lighting works fine. Any ideas that could save me some time on fixing this?
    Bad relay?
    ''It is what it is, Do what you want''
    http://www.cb7tuner.com/vbb/showthread.php?t=167905
      you might want to check all your relays or fues in the car and under the hood or you might just have a lose wire hope you fix
      92 cb7 http://www.cb7tuner.com/vbb/showthread.php?t=176886
      91 cb9 wagon
        All fuses are good. Which relay would be the most probable cause of this?
          Hazard relay.
          Henry R
          Koni/Neuspeed
          1992 Accord LX R.I.P
          1993 Accord EX OG since 'o3
          Legend FSM
