Drove to work this morning and everything was fine, went to lunch and still good but when i stopped to eat on my way back to work my windows didnt work, dont hear the motors and then i noticed that the rpm's werent working nor was the speedometer, checked all the fuses and everything is good there, dont know how to check relays but dont think thats the case, after doing little search i thought to check the code and to my bad luck, all BUT the back light, battery and fuel arent working so i cant pull the code.....any ideas on where to look? I just did a 5speed conversion and wire main harness tuck but i havent checked the harness cus of work and if it was the harness wouldnt i have trouble starting the car? Any help greatly appreciated
window and half of my cluster stopped working
I got a 93lx for free cus the same issue took me 10 min to go through the fusebox and fix the problem hahahaha, but your wire tuck may have somethin to do with it so id triple check the fuses then inspect the wires
http://www.cb7tuner.com/vbb/showthread.php?t=187851
sold to: cb7rush\h22-accord\Luis\BurtonRiderT6
bought from:jokerxfn-tommi-'93cb7ex
Replace the ELD. Electrical Load Detector. What it basically does is regulates the amount of voltage from the charging system on the car. If that fails then you'll have that issue your describing.
Its located on the engine bay fuse box..and has a 3 wire connector that plugs into it.
Find a spare box though..taking that ELD is a pain in the ass because you have to undo the fuses and seperate the upper and lower half of the fuse box.Henry R
Koni/Neuspeed
1992 Accord LX R.I.P
1993 Accord EX OG since 'o3
Legend FSM
Originally posted by GearBangnAccord View Postcheck your grounds.. do any windows work??
Originally posted by Accrdkid View PostReplace the ELD. Electrical Load Detector. What it basically does is regulates the amount of voltage from the charging system on the car. If that fails then you'll have that issue your describing.
Originally posted by Uncle WilleyWhen I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
damn, think my wires are even more screwed than i thought, or prob just me.....when ur headlights are on and car is on aswell and you open the driver door is it supposed to chime?
Originally posted by JaberCB7 View Postdamn, think my wires are even more screwed than i thought, or prob just me.....when ur headlights are on and car is on aswell and you open the driver door is it supposed to chime?
Originally posted by visualpoet View PostMine doesn't chime when it's running. I think you have issues with your tuck. Did you solder and heat shrink everything, or twist and tape?
Originally posted by JaberCB7 View Postbutt conectors, tape, and wire covers and i did one wire at a time to ensure that everything gets wired right, it was fine for the first week i got the car 100% running.
Originally posted by visualpoet View PostBeen humid or wet in your area lately? It sounds like you might have some corrosion issues in your connections. You'd be surprised at how easily moisture can invade splices. I could be wrong, maybe you just have a loose plug or a pulled out wire, or it could be something previously suggested.
just looked up the part im talking about, wiper arm linkage bushing
get some free time. and start breaking sh@t down. Most
likely its your harness. Check right at the plugs too. Make sure
none of the wires are loose. Lightly pull at them, in and out. And
feel for loose wires not making a good contact.
Also like others have been saying. Check your fuses. Make sure
you have the currents amperage in each fuse portion.
:Back In Business...
Originally posted by RyderzUnlimited View Postget some free time. and start breaking sh@t down. Most
