I just got my coupe from a dealer even. I'm sure the previous owner did NOT due a bunch of maint. before he traded it in. It ran fine, but I figured I'd anticipate some stuff and just do it. I couldn't get a history on the vehicle, so I assumed stuff probably had not been done... Anyway, here's the list!! Nothing out of the ordinary really.
• Timing belt
• Balance shaft belt
• V belts (2)
• Crank, cam seals (retainer clip)
• Water pump
• Thermostat (Flush/Fill with green)
• Valve cover gasket
• Fuel filter
• Air filter
• Driveshafts (AutoZone)
• Spark Plugs and spark plugs seals
• Spark plug wires (AutoZone)
• Cap, rotor
• Battery
$500 for labor. I think I'm set for awhile. The boots were just ripped on the shafts, but it was only a matter of time. You guys mightg wanna check your axle boots because they do get torn over time.
• Timing belt
• V belts (2)
• Water pump
• Fuel filter
• Air filter
• Cap, rotor
• Battery
