Would a wet dizzy cause all these problems? I gave the engine a bath, but now it bogs down, pops, and sputters quite a bit. I can't get it higher than 3500rpms without it trying to cut itself off and if I try to hit the gas from a dead stop, it acts like its choking to death. When I try to start it, the starter cranks and the engine turns, but when it tries to ignite the fuel, it pops once or twice then dies. ECU threw out a Code 1, but I still don't know what to do. What could have happened and how do I fix it?
Edit: When I went to the local Honda dealership and gave them the ECU and TCU codes, they came back and said "replace the distributor. Most likely the distributor is corroded."
