Key ignition STUCK!!!
    hey whats up I got a problem man.. I go to start my car and the key goes in the ignition perfectly and everything but it just wiont turn at all ... It feels when u try and start your car and its in like nutreal or something it wont budge... I tryed to get it to work for about 2 hours bangin around the steering wheel and doin all the tricks and shits but didnt move.... I dont even want a new one I want to take this shit apart and just use anything to start it.. anybody can point me in a direction to help me take this shit apart and start it up/......?? Thanks in advance.
    have you tried turning the wheel left and right while trying to start her up? i think i've been in your position a few times, and all i had to do was jerk the wheel around and then the car started. i think it's because you locked the steering wheel last time you were in it
    Click Here for My Member's Page | Free money for searching the web. Needs PayPal account
      yea I was bangin it left and right doin everything trying diffrent shit like trying to startin the car when the steerring wihell was in all position alllllll the way to the left and all the way to the right and in between..
        same thing happened to me try forcing it in the off position as much as it will go when i did that on mine it sliped back a little and solved the problem
        H23?
          thanks for the ieas but please ppl post as many ideas as u can cuz I nee dmy acr and Iama try every one so if one dont works I want to try the other when I get off work.. Thanks in ADVANCE!
            is ur car automatic????
              I have an ignition from my accord i can sell to you with the key. let me know
                Tried taking the key out ant turning it around?
                It sounds like a bad tumber in the ignition lock to me. Solution: replace the tumbler.
                  It's definitely the tumbler, and it's exspensive to replace. On top of that, you might want to bring it to a mechanic if you are not mechanically inclined.
                  My Member's Ride Thread, Comments Welcome!!!
                    no man just take ur time with it.
                      Is there anyway I can take apart my ignition and just turn it on with anyting? I know some cars u can do that ones the ingition is taken apart.. jhow would I go aboutdoin this??
                        And yes it is a automatic.. If ther eis anyway I can like hot wire this shit everytime I will... I just need my car asap !!!!!
                          you probably could, but that's ghetto as hell. :thumbsdow
                            It is in Park right? :P
                            To-Do List for Today
                            Be Awesome
                              my car some times does the same shit i turns on perfectly but the then i turn the car off and the key dont turn to get it out i use a thin ass screww driver and push on the side where ur key goes in that hole part goes in when u turn the ignition on try that if it helps
