02 sensor caps?
    02 sensor caps?
    Has anyone heard of a cap for 02 sensors so that catalytic converters can be removed and and post cat o2 sensors wont throw CELS???
    "This truck is 100% sh*ts and giggles."
    "Speed has never killed anyone. Suddenly becoming stationary... that's what gets you." Jeremy Clarkson
    You're not JDM until you have a car built in ohio with tons of bolt ons from ebay.
    Disregard females, acquire currency
    BUS 62 AIN'T F'ING AROUND!
    search for simulators.
      o2 simulators? awesome thanks man I had no idea what they were called.
        they make shit for everything anti-emissions, lol.
            Yea, my buddy has it on his V6 CG in my sig. I think another name is De-fouler or some shit like that.
            1993 Accord LX - Sold
            93 BMW 525it - SOLD
            92 Accord EX Sedan - SOLD
            2000 Accord Coupe - Traded-In
            2003 Accord V6 6spd Coupe - Sold
            2001 Honda Civic Ex - SOLD
            2013 Chevy Traverse LTZ - Kid hauler
            2003 Acura Tl 3.2 - Daily Commuter
              Yep. Good call wed3k.
              Found o2 simms on fastmans and I learned about the kat box.
              They way I found out about these, they just were caps that went over the o2 sensor. Apparantly, if I understand correctly, they replace the o2 sensor.
              I read one thing where the guy went to straight pipes, then zip tied the o2 to his frame rail... I'm wondering if that would work on mine... IDK, so much to think about.
                the o2 would sense too much oxygen and may set a code. these caps produce a voltage simular to a healthy cat.
                  5v right? Basically the rear o2 sensor should not detect anything, if it does this means the cat is not working so the code throws.
                  You could just get a proper sized cat and be environment/my lungs friendly
                  ____
                    narrowband o2 works on 0-1v...higher the oxygen, lower the v. a healthy cat will use all the oxygen for the oxidation process.
                    most cars are so clean already that it will pass emissions fine without a cat. it's insane because it'll still throw a code for a catalyst inefficient P0420. ive seen a supercharged trd tacoma pass emissions but have a CEL for p0420.
