EGR blocked off, can EGR ports still be a problem?
    i have egr and fitv blocked off without problems. what brand o2 sensor did you get? if it's anything other than denso or ngk/ntk that could be the reason for low mpg
    2013 Ice Cream Cruise!
    VIDEO: 2012 Ice Cream Cruise
    August 3 ~ Omaha, NE
    By 1320 Video
    Member's Ride Thread
      Actually it was getting good mileage at first, the plugs got fouled with a few times and probably just need to be replaced. Code 43 disappeared when I reset the ECU
        sorry to hear this man lol
        i blocked EGR and left it off and unplugged car is fine to me
        also removed all evap and emissions conrol stuff along with it
        i was thinking aboutdoing the iacv block too but seein how your having trouble im not too sure if i wanna do it now
        what about FITV block off ?? anybody know anything about it
        -Tyler
          The FITV has no connection with the ECU, its only modifier is coolant temp so no CEL there. I had my FITV blocked off, and the only real difference was no high idle while the car is warming up. Not the greatest idea in a cold climate.
          The IACV can be blocked off, but the valve itself must be left plugged in or the engine will be in limp mode with code 14.
            Yah, I didn't think the code 14 would actually give you limp mode. That's the crappy thing about fuel injection.
