I am needing to do some a/c work as my condensor has a hole in it. I have been trying to find some vacuum pumps and I have found many ranging in price from $75-$300...and some of these $75 ones are 1.5-2 cfm and some of the $300 ones are also in that range but usually 6cfm.
I am wondering if anyone else has any experience with using these and can give me some advice...as in...can I use a 1.5 or 2 cfm pump like this? Do these typically have fitting that will work with r-12 and/or r-134 systems? Is there anything special required to make it work for that application? (I know the fitting are different but mainly wanting to make sure all I need to do is buy the fittings...not like...drill and tap new holes or buy like 5 adapters of something)
These are what I am looking at;
FJC 6905 1.5 cfm Vacuum Pump (google search link)
and
Nex Tag search
lastly a google product search yielded these for ...Ten dollars? riiiiight
I have also seen the ones that you hook up to an air compressor, but from what I have read you have to have a mid sized tank (20+ gallons) as you have to apply a constant 90psi to get them to work...and they are good for 2-3 vacuum pulls. Plus you have to leave them on for a VERY long time...wasting a LOT of electricity.
More importantly I do not currently have an air compressor at all right now, I will be getting one in a few months but most likely not that large...so I am really wanting to get an electric vacuum pump if possible.
Any one have experience using these? When I worked at a shop I did not have to worry about such things, equipment was provided
and
Nex Tag search
