Has any one does this before? just wondering if its cheaper the do than buy the lines it self from the dealership or parts store. changing the P/S pump and rack cuz they are both shot. and wanting to replace lines so there is no contamination of the old fluid ruining the new fluid. or does it matter at all? the pump leaks like crazy at the moment
AN lines to repalce P/S lines
my dad and i changed the line.. PITA.... make sure you dont mix up the lines...
you can flush the lines using honda power steering fluid.. i don't recall the exact procedure. but you can flush the lines.
if the lines look good i'd say don't replace them (I had to because they were all rotted out)... if they look good, flush them.
hope this helps. oh and it can also be a pain to get all the air out of the system...
