porportioning valve
    porportioning valve
    hey where is the porportuning vavle, fuk spelling hehe.
    i was wondering for the rear disc conversion
    Retro!
    Hater
    Pop the hood, follow the 2 lines from the master cylinder and u will see a junction where it turn to 4 lines. That "junction" is the proportioning valve.
    PURCHASED NOVEMBER 1991. THAT'S RIGHT, I'M THE ONE AND ONLY OWNER. BEAT THAT!
      exactly, and you need the one from a 91-93 teg with rear disc brakes.. you should also get the vtec lude master cylinder, while you have no pressure in your lines.
        90-93 integras...I know, I had a 90 integra GS sedan 5spd with rear disc
          get one for the RS, it had no abs.......idk if it makes a difference or not in the valve. just a useful peice of info i thought u guys could use.
          Finally Up and Running. Numbers to Follow. Check my MR
            my dad has an 88 integra RS 5 spd 3dr coupe that has rear disc....just FYI
              would there be any wrong doing in NOT doing the valve?
              should i put the master cyl from a 92 93 accord?
              i found it all for 100 bucks at the local junk yard =)
              oh yea and it sucks 5th gen doesnt bolt up \= oh well found 2 4th gens
              Retro!
              Hater
                http://www.accordinglydone.com/forum...ight=rear+disc
                that guy talked about porp valves, in that integras are 40.40 and accords are 20.25...anyone care to explain?
                will i get better turn out with the tegs porp?
                Retro!
                Hater
                  See if you can find out if the 92-93 proportioning valve is different than your model year.
                  Check the same thing with the master cylinder
                    I know the F22a6 master cylinders are larger than the F22a1/F22a4 Accords on 4th gens. We have a 91 SE and 90 EX at home, I've bought both BMCs.
                      I pulled off hondanet to confirm
                      F22A6 Master Cylinder Assy. - 46100-SM4-G54
                      F22A1 Master Cylinder Assy - 46100-SM4-A04
                      When I searched Integra they say - Master Cylinder Assy. (A.L.B.), now maybe I'm slow but doesn't that mean Anti-Lock Brakes? And their part number is - 46100-SK7-A53
                        i'm running on the stock prop valve after my disc brake conversion and i can still lock up my 17's with 215/45 on the freeway. it's been over one year now and it's still all good. i'm even using the stock LX master cyl and booster. i guess it all depends on the condition of your existing equipment.
                        if i can find a prop valve from an integ 90-93 non-abs, i would put it on and give you guys the results, but for now i feel that i'm a-ok. i've heard that it's the brake booster that should also be replaced on top of the master cyl. any insight?
                        1cor10:31
                        - 92 LX coupe
                        - 96 EX wagon (sold)
                          well after my rear disc swap, and my front=rotor over hub conv, with lude vtec calipers and discs, i am going to install the BMC from the lude vtec too... so we will see if it is a diff size or not..
                            what do you mean by locking up? i mean i know what it means, but does that mean you can do it more than before you did the conversion?
                            Retro!
                            Hater
