car bogging / jerking
    so ive read all of the bogging and jerking threads on this forum and i have an idea of what it could be, but my situation is different from the threads ive seen.
    in a 40 minute drive, mostly highway, the car will jerk / bog more than 30 times
    and its a slight jerk that i can feel, it scared me when it first happened but im getting used to the feeling. rpms wouldn't drop too much, about 100 or so, lasts for 1 second at most. sometimes it even does 2 consecutive jerks / bogs
    it happens very frequently during my morning drive to school, but on the way home its alot less. and i also notice if i don't warm up my car enough, it will also more likely jerk / bog in the lower gears and speeds
    so from what ive seen on the threads, it could be my o2 sensor, my first guess was a dying fuel pump. Fuel filter is new, just did a tuneup, no CELs. for the most part the car drives pretty good, its just these random jerks / bogs. also my car is stick.
    MY CB7
    FULL part out thread:
    http://www.cb7tuner.com/vbb/showthread.php?t=204494
    Ok, mine did this onece and i gave it a new plugs and wires,button and it fixed the jurking prob.
    kiss my grill
    Members Ride
      might be time for new plug wires, also check the sparkplug tubes to see if they have oil in them if you find oil ,time to change the v/c gasket and tube seals.........
        X2ND that as well .
        I had oil in my spark plugs and when I went to change the gasket seals , my friend said that it was wierd that my car wasn't jerking , bogging out because there was a good amount of oil in the chambers.
        Check Out My Work In Progess . . . . .
          A tune up cap amd rotor plugs and wires will do great for ya get ngk plugs though
          current cb 93 10th ann. edition
          member ride thread >>> http://www.cb7tuner.com/vbb/showthre...73#post3257973
            try cleaning your egr ports too
              egr ports cleaned, plugs cap and rotor new.
              wires haven't been changed yet, and theres oil in the sparkplug holes
              but its been in there for years without any jerking problems
              so i think i should look elsewhere for the solution, haven't fixed the oil in sparkplugs problem because im gonna swap in a different f22 soon
              MY CB7
                i also noticed that it happens when i keep the rpms consistently the same.
                but when im accelerating it doesn't happen.
                MY CB7
                  sup Benson! is Luis im the guy with the white coupe that had frame damage.. i noticed you said you were gonna get a new f22 soon... so why try to fix the issue on this one? i have oil in spark plug cyl2 and it runs fine.. i do however have a slight missfire because of it.. anyway good luck with ur problem son
                    Hey luis, the problem might not be from the engine though
                    Could be the fuel pump or the o2 sensor, that's why im trying to figure out what it is
                    MY CB7
                      Now that I remember my old cd5 had this problem..sorta... it would not wanna go anywhere when I was on the hwy and stomped on the gas.. it would catch after like 5 seconds and it would missfire.. I ended up having a code 43 like a month after I had that problem.. switched out the o2 and cleaned my egr ports and it was running like a champ.. maybe u can go to the jy and swipe a couple of o2's.. id give it a shot and then go from there..
                      I don't think its the fuel pump since ur problem is only during one condition
                        hmm thanks for the advice
                        i think ill wait a few more days and see if a code comes up
                        MY CB7
                          Ran into the infamous code 43 this week myself, I started with the filter since it was cheaper option, it was clogged and weighed twice what the new one did. Swapped in a universal 4 wire laying around and all is great now. I have noticed alot of threads suggesting a fuel pump issue or most ppls first thought is its their fuel pump. If your gas cap is holding massive vacumn when at the gas pump the I wouldnt worry about the fuel pump first.
                          Good o2 sensor link.....has a wiring color chart for cross reference.
                          http://www.aa1car.com/library/o2sensor.htm
                            Glad you solved you issues, but......the old fuel filter was heavy because it was soaked with fuel. Not saying it wasn't dirty but the "dirt" is a negligible weight.
                            My Member's Ride Thread
                              I here you but im not to sure about that...the O2 was definatley the original considering the amount of force applied to remove it via a really long breaker bar to bust loose. Either that or it was replaced without the use of anti-seize.
