ok so my steering wheel has a very noticeable wobble when i drive it, but im not sure what is causing it. The wobble is nearly un-noticeable at lower speeds but once i hit from 60 to 70 mph, the wobble becomes fairly violent and after i pass 70mph it seems to go away. I have several ideas as to what i could be but im not exactly sure. Any help would be appreciated
steering wobble
Tie Rods my friend my is doing the same thing esp if you notice play in the wheel at all. And this could also be your ball joints as well. Check those out and get back ASAP!!! Hope this helps!!!The CB7 Collector.Team Kindred Impulse Member #392 LX Coupe F22A12013 Toyota Corolla S92 EX Sedan F22A1Originally posted by deevergoteDo you really need to make a thread asking if having your car like this /---\ will cause uneven tire wear? Try walking like that for a few weeks and see if your shoes wear funny! (hint: they will.)
I had some extra parts lying around but if you check out tasauto.com it shouldn't not much more than 200 bucks for a full refresh if you wish to call it that.The CB7 Collector.Team Kindred Impulse Member #392 LX Coupe F22A12013 Toyota Corolla S92 EX Sedan F22A1Originally posted by deevergoteDo you really need to make a thread asking if having your car like this /---\ will cause uneven tire wear? Try walking like that for a few weeks and see if your shoes wear funny! (hint: they will.)
definatly sounds like tires are out of balance
member ride thread >>> http://www.cb7tuner.com/vbb/showthre...73#post3257973
alignments do not cause vibrations unless its riduclous like toe angle out 20 degrees fyi
lol well i guess mine was that bad lol. Mine was almost like a bounce.kiss my grill
Members Ride
