Just curious, you know when you crank over an engine to start it and hear the starter spin the flywheel?
Mine doesn't make that smooth, fine sounding electronic engagement like any normal Honda engine would. It sorta sounds rough like a lot of friction is going on.
Are F22 starters different than H22 starters? dimension wise? I know they bolt up but are the number of teeth different? What about power wise for the starter motor?
The starter I'm using is out of an F22, and its bolted to my 5spd H22 engine/trans, just wondering if that's alright or you think I'd need an H22 specific starter. Just sounds kinda rough, idk how else to describe it
