what are some things to look for if the main relay is bad? i just picked up one at the jy today and the it looks a little corroded and there is this brown sticky looking stuff on it... any help and/or advice would be appreciated.
main relay... good or bad?
Open it up and visually inspect all the soldering, thats how they go bad, the motherboard expands and contracts with heat and cold, as a result sometimes the solder seperate. Look for hairline cracks in the solders.
http://www.cb7tuner.com/vbb/showthread.php?t=187851
sold to: cb7rush\h22-accord\Luis\BurtonRiderT6
bought from:jokerxfn-tommi-'93cb7ex
if you have a soldering iron handy, I would just go over all the solder connections and "refresh" them. Overtime, I'm sure you know, the solder joints crack and thats what causes that issue.
Also another idea I found is to drill holes in the case of the relay, that'll help w/ cooling in the future. It gets hot sitting up inside the dash.
